05-17-2016 08:50 AM
Hello fellows.
I can't seem to open de app of proximity in my MacBook Pro - OSX El Capital 10.11.5.
I am able to install the App, see it in my applications - but it won't respond when i want to open it.
Any ideas on what to do? i have updated my OS version to the latest. Erased ad re-downloaded the App several times.
thank you.
05-24-2016 04:18 AM
Once you have started the app you can find it in the OSX menu bar. Its in the top right part of the screen. To the left of battery indicator. Press the icon and you get an option to share your screen to a video system.
05-26-2016 01:58 PM
Dan, thank you. The app never starts, it like crashes... i haven't been able to see the little proximity icon in the top menu. I even re installed my OS. And still no luck.
05-26-2016 11:41 PM
Please try the following.
1. Delete all files in /tmp that starts with proximity
2. Try starting proximity
3. Send all files in /tmp that starts with proximity to me, daneriks at cisco.com
Thanks.
Dan
05-31-2016 08:18 AM
Thank you Dan. I did as instructed, had no luck. The email should be in you inbox by now.
Thank you again for all your support.
06-26-2019 01:50 AM
same problem as fmontesino. My Mac verson is EL Capitan 10.11.6
I could still use it 2-3 months ago for a while. About 3-4 weeks ago, when I clicked the cisco proximity, it jumped out, no response. I did deleted it and restall again, same thing.
06-26-2019 04:19 AM
We no longer support Mac OS 10.11. The recent versions of Proximity have only been tested with later versions.
06-26-2019 04:21 AM
