03-07-2022 05:41 AM
Hi All,
Is allowed direct upgrade from Bengaluru-17.4.1a to Cupertino-17.7.1a? Or is there some middle step with other IOS version?
I've checked release notes for C8200 and 17.7.x but there isn't this kind of details
I see only that there is needed newer ROMMON version 17.4(2r).
Solved! Go to Solution.
03-07-2022 06:17 AM
That is correct you need to go to 17.4(2r), then target version of your desired one.
03-07-2022 06:51 AM
Thank You.
03-09-2022 04:22 AM
Hi Balaji,
Do You know documents describing ROMMON upgrade and You could share with me? I can't find separate files of ROMMON SW on Software Download. Maybe ROMMON upgrades automatically during IOS upgrade but I can't find confirmation of this procedure.
03-07-2022 06:17 AM
03-07-2022 06:51 AM
Thank You.
03-09-2022 04:22 AM
Hi Balaji,
