04-11-2023 04:38 PM
We have two Cisco Nexus 931080YC-EX (I believe they are EX but can't remember at this moment). They are running the NXOS for 32 bit. I have just upgraded them to nxos.10.1.2.bin.
Is there a way to convert these switches to 64 bit or am I stuck for ever on this nxos version?
Solved! Go to Solution.
04-12-2023 08:10 AM
as i mentioned before some model do not support that architecture(example your model as per i know do not support) , so you need to have model which can support both 32 and 64bit.
04-12-2023 02:37 PM
thank you to Cisco TAC Andres David Pinilla Garcia >>
I just reviewed our upgrade matrix and the jump you are trying to do is not supported:
10.2(1)F → 10.2(5)M → 10.3(2)F
This means that in order for you to upgrade to 10.3(2)F you need to go to 10.2(5)M first.
04-11-2023 05:36 PM
You can go upto 10.3(2)(f)
But stable suggested version is 10.2(4)(M)
read the release notes :
Cisco Nexus 9000 Series NX-OS Release Notes, Release 10.2(5)M - Cisco
Also, read this EOL statement:
04-11-2023 05:53 PM
My switches do not recognize the nxos64 images. Is there a way to convert the nexus switch from nxos to nxos64 images?
04-11-2023 07:21 PM
Cisco switches not like a White box, they build the OS based on the architecture.
you can not load and install what ever the image you wish to install.
nxos64 images << not sure what image is this, you need to provide more information and evidence of your installation steps ?
post show version also
04-12-2023 05:39 AM
I am currently running image nxos.10.1.2.bin. The next image for the Cisco Nexus 931080YC-FX (Not EX model) is nxos64.10.2.1.F.bin. It does not recognize the image. How do I get this switch to recognize the image?
04-12-2023 05:47 AM - edited 04-12-2023 10:31 AM
For any one check this post later
For 32-bit or 64-bit image support on respective platforms, see the following documents:
Cisco Nexus 9000 Series NX-OS Release Notes, Release 10.1(2)
Cisco Nexus 9000 Series NX-OS Release Notes, Release 10.1(1)
04-12-2023 08:10 AM
04-12-2023 10:35 AM
Just noticed that model number is wrong. Actual model is N9K-C93180YC-FX.
04-12-2023 10:37 AM
Friend just check link I share above
MHM
04-12-2023 02:37 PM
04-12-2023 04:10 PM
Sorry can you more elaborate' you meaning platform support nx-os 64 but you can not upgrade directly?
