Cisco Nexus 931080YC-EX 32bit to 64bit
Jeff Horton
We have two Cisco Nexus 931080YC-EX (I believe they are EX but can't remember at this moment). They are running the NXOS for 32 bit. I have just upgraded them to nxos.10.1.2.bin.
Is there a way to convert these switches to 64 bit or am I stuck for ever on this nxos version?
2 Accepted Solutions
as i mentioned before some model do not support that architecture(example your model as per i know do not support) , so you need to have model which can support both 32 and 64bit.
BB
Jeff Horton
thank you to Cisco TAC Andres David Pinilla Garcia >>
I just reviewed our upgrade matrix and the jump you are trying to do is not supported:
https://www.cisco.com/c/dam/en/us/td/docs/dcn/tools/nexus-9k3k-issu-matrix/index.html#cur=10.2(1)F&tar=10.3(2)F
10.2(1)F → 10.2(5)M → 10.3(2)F
This means that in order for you to upgrade to 10.3(2)F you need to go to 10.2(5)M first.
10 Replies 10
balaji.bandi
You can go upto 10.3(2)(f)
But stable suggested version is 10.2(4)(M)
read the release notes :
Cisco Nexus 9000 Series NX-OS Release Notes, Release 10.2(5)M - Cisco
Also, read this EOL statement:
End-of-Sale and End-of-Life Announcement for the Cisco N9K-C93180YC-EX and Cisco N9K-C93108TC-EX - Cisco
BB
My switches do not recognize the nxos64 images. Is there a way to convert the nexus switch from nxos to nxos64 images?
Cisco switches not like a White box, they build the OS based on the architecture.
you can not load and install what ever the image you wish to install.
nxos64 images  << not sure what image is this, you need to provide more information and evidence of your installation steps ?
post show version also
BB
I am currently running image nxos.10.1.2.bin. The next image for the Cisco Nexus 931080YC-FX (Not EX model) is nxos64.10.2.1.F.bin. It does not recognize the image. How do I get this switch to recognize the image?
For any one check this post later
For 32-bit or 64-bit image support on respective platforms, see the following documents:
BB
Just noticed that model number is wrong. Actual model is N9K-C93180YC-FX.
Friend just check link I share above
MHM
Jeff Horton
Sorry can you more elaborate' you meaning platform support nx-os 64 but you can not upgrade directly?
