Supported maximum rtt for stackwise virtual
rightsedfred
I'm considering put one C9500-24Y4C-A each site and connect the site with WAN.
Although I would like to connect C9500-24Y4C-A each other by StackWise Virtual(VSS), I'm not sure the prerequisites such as the supported maximum round trip time(RTT) and minimum network latency.
I would be grateful if you could answer for my question. Thank you.
balaji.bandi
If we talking about forming SVL between 2 switches, this will be dedicated link of SVL - the document never mentioned any limitation., i mentioned as support large distance, i tested 1 with 4mile works ok. ( chcek the requirement of SVL link capacity as suggested)
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9500/software/release/16-6/configuration_guide/b_166_ha_9500/b_166_ha_9500_chapter_01.html
BB
balaji.bandi
BB
Thank you for your immediate answer!
