Any tips or thoughts on how to maintain the .arf quality when converting to .mp4 or .wmv
mtarallo1
Hello WebEx Community - I have attempted several times to convert my .arf to a .mp4 and a .wmv file. I am attempting .swf as we speak to see if that makes a difference. After conversion both the video and the audio quality are not as good as the original .arf quality. I am tempted to use Camtasia screen capture and record system audio to get the best quality, but find that if I must do that completely ridiculous. Is there a way to convert a WebEx .arf file to a high quality video - where the quality is the same as the original .arf?
Any suggestions are appreciated.
Mike
dpetrovi
Hi Mike,
Unfortunately, this is the limitation of NBR Recorder.
http://www.cisco.com/c/en/us/td/docs/collaboration/CWMS/2_5/User_Guide/User_Guide/User_Guide_chapter_0111.html#task_CCFCBC5C2B704CA585059FA0A50B6DDE
"On the original recording (either streaming or downloaded), video and audio quality is good (24+ frames per second). After converting the recording to WMV or SWF format, you might find that the audio and video appear to be significantly downsampled (5 Frames per second)."
-Dejan
Thanks Dejan - I converted to .swf - which really creates 2 .flv files - then I am using a tool called xMedia - to encode to .mp4 - we will see how that goes.
Thanks for your reply.
Mike
