Audio Broadcast vs Webex Audio
ryan2019
What is the difference between Audio Broadcast and Webex Audio in terms of bitrate, frequency range, codec, etc?  Is Audio Broadcast better for live music streaming or is Webex Audio as good in terms of audio quality as long as super wideband is being used?  I can't find any specifications on Audio Broadcast option except it's 3,000 capacity.
Thanks.
Jonathan Schulenberg
Audio Broadcast is G.729 and is ancient feature. I recommend using Webex Audio which will eventually replace AB entirely.
What are the requirements to ensure that webex audio is in super wideband
mode?
To my knowledge the user cannot control it other than to use VoIP audio in the meetings app (https://help.webex.com/en-us/WBX83754/How-Do-I-Verify-that-Wideband-or-Super-Wideband-Audio-is-being-Used-in-a-Meeting), a SIP URI call from a capable room system, or Webex Edge Audio (G.722).
