I'm looking for an eFax or FoIP solution for my CUCM v10.5. From an Administrator standpoint, I'd like to get some opinions on what type of solution you're using and how easy is it to work with. Is it buggy? Is it easy to administer, or do you have to work out kinks regularly? Do the users like it? So far, I've checked out RightFax's on-premise fax server solution and XMedius's Cloud hybrid solution and can't make up my mind. I'm looking for some great feedback from those in the know before making a decision. Thanks in advance. -Beth
Hi Mike- thanks for the response. We are looking at using email as primary endpoints. I'm not up on all the jargon - what is SAP integration? -Beth
Hi Beth,
We (CommSouth) are a third party solution provider offering many applications on top of Cisco solutions. Fax Over IP (FoIP) is one of our solution and we can address all your requirements. For more information, you can visit our website www.commsouth.com, http://www.commsouth.com/downloads/IPFaxServer_Brochure_EN.pdf
***Please rate if useful***
I’ll offer an up-vote/recommendation for XMedius, either their cloud or on-premises solution. They have been my go-to fax server for a decade. You may also want to consider whether the MFPs you have on-site are supported by the fax server through a connector. This has a couple of advantages including eliminating FXS ports, giving centralized monitoring/archival/troubleshooting, and allowing users to slap a document on glass/ADF and faxing directly from their DID/identity instead of the shared number of the MFP.
