Auto-Population of Jabber Contacts by AD Group
detinater
Is it possible to have the Contacts field in Jabber be auto-populated with members from a specific AD group? For instance if users are added and removed from say the "Staff" AD group, will it add/remove those users automatically when syncing from AD into the Jabber "Contacts" list?
I can't seem to find an answer for this. I know you can manually upload a contacts list, but that's kinda a pain when you could potentially sync it from a Group that is maintained automatically.
Thanks!
Hey Jaime, thanks for the reply. I actually have all that configured and I can pull the group into my Jabber. What I'm wondering is if there is a way to automatically assign said group to all my Jabber users so they don't have to go search for it and add it themselves.
Nitpicky I know, but sometimes the easiest thing to do is the hardest for some of them.
AFAIK that's not possible, you would need to create a small doc of how to add the group(s) they should have and explain they will not be able to add/remove contacts from them as they're centrally managed.
java
if this helps, please rate
