C20 Camera Control Cable
Dean O'Meara
All,
I have an old c20 that I would like to power back on however the camera cable is missing (the one used to power the camera from the codec)
I have tried purchasing an RS232 to RJ45 cable but the camera still will not power on, does the cable cisco provide have special pinouts?
If I use a power supply the camera powers up fine, I am using the x12 zoom camera.
JFerello
Yes you need a specific cable, attached is the pin out.
Justin Ferello
Wayne DeNardi
You have posted this question twice.  Refer to the answer provided in your other thread: https://supportforums.cisco.com/t5/conferencing/c20-camera-control-cable/m-p/3405807
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
