Cisco CSSM || Smart Satellite upgrade process Version 8 Release 202102
James Hawkins
Level 8
Level 8
Has anyone had any luck upgrading CSSM On_Premise to the latest version?
In previous versions I think you were able to upload the required files to the /var/files/patches directory using WinSCP or similar.
Now when you try that you get a permission denied response.
The install guide says the process is to go into onprem-console mode and then copy the files off an SCP server using the command below:
copy <your username>@<your remote host>.com:/path/SSM_On-Prem-8-202102_upgrade.sh patches:
I tried this using a Windows SCP server (BitVise) and got a failure message saying the following:
Operating in CiscoSSL FIPS mode
FIPS mode initialized
Unable to negotiate with 10.0.4.245 port 22: no matching host key type found. Their offer: ssh-rsa,ssh-dss
I tried a different Windows SCP server (Solarwinds) and am now getting the failure message below:
Warning: Permanently added '10.0.4.245' (RSA) to the list of known hosts.
ssh_dispatch_run_fatal: Connection to 10.0.4.245 port 22: incorrect signature
It looks like the server has saved the SSH key used by the first SCP server software I tried and will not allow the second server to be used because the key is different.
There do not seem to be any commands to clear the cached keys available - I guess I could boot from a CentOS ISO and try to work out how to do that but I am very angry that Cisco have made this whole process so unnecessarily difficult - how this software made it through testing baffles me.
If anyone has any recommendations for an SCP server that might work to upload the patches please let me know and, if anyone can give guidance on how to clear cached SSH keys please share that too.
22 Replies 22
Try Bitvise Client instead of WinSCP.
Thx, but the solution was using scp instead of sftp
This was also the fix for me. Thank you Hubert.
hostas ehh hiibrocht?
Trying to upgrade my on prem CSSM from 8-202010 to 8-202108.  Having trouble with the copy command in step #6, getting error "permission denied".  I'm logging in using admin account.  Do I need to use a different account?  (i.e. root?)
andy1176
Some additional hints for the SSM running in STIG Mode to upload the upgrade image.
Solution provided by TAC.
From the CLI of the SSM:
>> curl -k -u ftp-user ftp://IP_Address/ipsla-test-ftp.txt -o /var/files/patches/ipsla-test-ftp.txt
or
>> curl -k -u admin ftp://IP_Address/SSM_On-Prem_8-202108_upgrade.sh -o /var/files/patches/SSM_On-Prem_8-202108_upgrade.sh
This was a solution for us to upload the upgrade image to the SSM (running in STIG mode)
I know it's been four years since this issue was discussed but I have one question. Can I use my Prime Collaboration Deployment server to do this in STIG mode? I have a client that is about five years out of compliance and I cannot get files transferred to my satellite server. I'm getting a Failed to connect message using this syntax from the CLI of the SSM server...
curl -k -u (username of PCD server for file transfers) ftp://(server IP address)/SSM_On-Prem_8-202212_upgrade.sh.sha256 -o /var/files/patches/SSM_On-Prem_8-202212_upgrade.sh.sha256
Any assistance is greatly appreciated.
Michael Berry
Hi, hopefully this helps others as an alternate solution...  The incorrect signature error is due to FIPS being enabled and it can simply be disabled for the duration of a copy session by running "export CISCOSSH_FIPS_MODE=no" under your "admin" user or via sudo for the root user.  I believe the onprem-console may kick off the copy command as root/sudo.  Otherwise, you can edit /etc/environment and update with "no" for the FIPS variable and reboot...
