Cisco Flex vs Flex Plan 3.0
Anwar Safian
Hi expert
Could I know what is difference between Cisco Flex and Flex Plan 3.0?
Vaijanath Sonvane
The following options are not available in Flex 3.0:
  • On-Premise Contact Center
  • Webex Contact Center / Webex Enterprise Contact Center Enterprise
  • Cisco Meeting Server
  • Active User Meetings
The above options are only available in Flex 2.0. The major one is "Active User Meetings". If you have a customer who is looking for active user meetings, then Flex 2.0 is the only option.
If you are Cisco Partner, then you can obtain following guide which highlights the difference between Flex 2.0 and Flex 3.0:
https://www.cisco.com/c/dam/en/us/products/se/2020/11/Collateral/collaboration-subscription.pdf
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
Flex 3.0 is and improved  collaboration by bundling Cisco Webex Meetings and Calling have a look on below datasheet.
https://www.cisco.com/c/en/us/products/collateral/unified-communications/cisco-collaboration-flex-plan/datasheet-c78-744220.html
Response Signature
Vaijanath Sonvane
