12-09-2016 08:18 AM - edited 03-17-2019 06:33 PM
HI
I just upgraded from Jabber 11.7 for Windows to 11.8 for Windows. I didn't do a new install I installed over my previous install. All of my Contact Images are gone and my user list is showing email addresses instead of names.
I tried a Reset of Jabber. Any other ideas?
Thank you
12-09-2016 10:02 AM
Where did you have the directory integration configured?
12-09-2016 10:14 AM
I believe it pointed back to our Domain Controllers.... None of that changed and others that are using the new version are not seeing the same issues. Its' odd
12-09-2016 10:26 AM
OK, so you have no configuration, you're using the SRVs?
12-09-2016 10:32 AM
We use a Service Profile....
12-09-2016 02:22 PM
What do you see under connection status?
12-12-2016 06:17 AM
This is very odd! I uninstalled 11.8 and reinstalled 11.8 and everything connects without an issue. But if we use 11.8 it fails to connect to LDAP.
Everything else connects without an issue.
12-12-2016 06:21 AM
Hi Jaime,
We encountered exactly the same problem with 2 of our clients who are testing the 11.8 Jabber client.
The connection status for LDAP shows:
Status: Last Connection not Succesful
Reason: Conneciton Error
Address: Server FQDN
Protocol: LDAP
Error: Invalid Credentials
Directory UC Service:
Product Type: Enhanced Directory
Secure(SSL) connection to global catalog on port 3269
And Service profile is configured as:
Use logged on user credential is checked
Username/passwords are filled with a service user.
Search base is filled as well..
In Jabber 11.7 everything was working correctly. When we switch to UDS is working as well.
Do you know what is going wrong?
Thank you in advance!
12-12-2016 06:50 AM
How did you switch it to use UDS?
12-12-2016 06:58 AM
In the used service profile, check the checkbox: "use UDS for contact resolution." and set the primary, secondary and tertiary directory UC Service to <None>
12-12-2016 07:01 AM
Even though that same Service Profile works fine with 11.7?
12-12-2016 07:03 AM
Yes, it seems we have exactly the same issue..
12-12-2016 10:36 AM
Ok
This helped a little bit but I still have no images for people it does show their names again and not just their email address, but no images show for them like it does in the 11.7 version of Jabber.
12-12-2016 10:44 AM
UDS does not support pictures out of the box. This is a workaround we used and is temporary. I still need to investigate what is causing the directory integration issues. When we resolved it I will let you know.
