04-08-2016 11:22 PM - edited 03-17-2019 06:01 PM
I have configured Cisco Jabber 11 with RMA it is registered properly IM & Presence and CUCM services are coming but when I dail a call it connects but no voice is coming.
Solved! Go to Solution.
04-09-2016 01:09 AM
Is NAT reflection is configured at firewall ? Or you can analyze pcap in expressway in case of any port block at network.
Suresh
04-09-2016 01:09 AM
Suresh
04-09-2016 01:47 AM
Hi Ahmed,
Did you opened the port 2222.
As well the ports 36000 / 36001* or 2776 / 2777**
Please refer the firewall configuration guide for port to be open.
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/expressway/config_guide/X8-7/Cisco-Expressway-IP-Port-Usage-for-Firewall-Traversal-Deployment-Guide-X8-7.pdf
For testing purpose you can check which ports are getting blocked while re creating the issue.
Raaj.
04-09-2016 06:01 AM
I found same solution issue NAT was missing in External interface.
