Cisco Jabber Client not saving contacts.
rferullo
I have a user that is using Cisco Jabber for windows and loosing some of his contacts every morning after powering up his machine and starting the jabber application. It's alway
I have already cleared the jabber cache folders several times and uninstalled/installed the jabber client.
Has another ever seen this before?
Thanks in advance.
Jaime Valencia
The contacts are not stored locally in the clients, they're stored in the IM&P server in the DB, and then the clients pull the info from there.
I'd make sure that you see the contacts in the IM&P DB when you create them, and make sure they're still there the next day to determine where the issue might be.
java
if this helps, please rate
