Cisco Jabber for Microsoft Surface HUB
Teo
Dear community,
I would like to know if someone heard rumors or future plan to release a Jabber client for the Microsoft Surface hub.
Both a simple conversion and/or a dedicated one that includes the writing capability.
Unfortunately Surface Hub only runs Apps, more correctly Universal Windows Platform (UWP) packages - targeted for the Universal device family.
But is possible to deploy software (*.appx, *.appxbundle only) on-premises with System Center Configuration Manager (beginning in version 1602).
Thanks in advance!
Jaime Valencia
I suggest you reach out to your SE/AM for this information as roadmap information is NDA material and cannot be discussed in a public forum.
java
if this helps, please rate
Jaime Valencia
java
