Cisco Jabber for Windows on XenApp - One-Way Audio Issue
Yoichi Inoue
Dear All,
I am testing Cisco Jabber for Windows 9.0.4 on XenApp 6.5 environment, and I am facing issue that audio from Jabber to Physical phones is missing. But audio from Physical phone to Jabber is working.
On windows both microphone/speaker are working properly, but Jabber option Audio shows "Speaker is not found" and "Microphone is not found". Also I cannot change anything under Audio window.
I believe Jabber for Windows 9.0.x is supported on XenApp 6.5 environment.
http://www.cisco.com/en/US/docs/voice_ip_comm/jabber/Windows/9_0_1/b_jabber_win_icg_chapter_01000.html#JABW_RF_N98B227E_00
Is there any way Jabber to recognize or change the configuration of Microphone and Speaker?
Also is anyone testing Jabber for Windows on XenApp environment?
Best regards,
YI
9 Replies 9
Muhammad Maqsood Mushtaq
HI YI,
Is it XenApp 6.5 published Desktop or XenApp 6.5 published Application? Jabber only supports XenApp 6.5 published Desktop.
Maqsood
Hi Maqsood,
We are using XenApp 6.5 published desktop, and it should be supported.
Under Windows Control Panel, both microphone and speakers are working properly via XenApp. However Jabber option page does NOT recognize both (Citrix HDX Audio).
YI
Hi YI,
Please open a TAC case for further assistance.
Maqsood
Hi Yi
Did did you manage to get J4W to work in XenApp 6.5? I'm facing the same issue in J4W 9.1. I can't select headset in desktop mode.
Best regards
Kristian
Hi all,
we have the same problem. If a TAC case open on this?
There might already be a solution?
Kind regards
Chris
If everybody on this thread is referring to using Jabber on virtualized environment on SOFTPHONE mode, that's not supported.
Cisco Jabber for Windows  supports the following functionality in virtual environments:
  • Instant  messaging and presence
  • Desk  phone  control
http://www.cisco.com/en/US/docs/voice_ip_comm/jabber/Windows/9_1/JABW_BK_CA48EE46_00_cisco-jabber-for-windows-administration_chapter_01.html
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Now I'm trying to get J4W 9.1.2 and work on our stand-alone Citrix XenApp 6.5 servers. But I still can't select the headset in Audio menu. But the headset is showned in control panel. I'm running XenApp 6.5 in desktop mode.
Kristian
I have the same problem, tried up to Jabber 9.2.1 and still the same issut, one-way-audio on Xenapp 6.5 published desktops. The forwarded mic in Xenapp sends no audio to the remoteside.
In the audio recording and playback setting on xenapp desktop, I can see that both directions do react and another audio recorder is working.
When I login to the same Xenapp Server via MS RDP, the Jabber is working great.
any hint?
thx
Daniel
Jaime,
Sorry but unable to lacate your statement in the link you provided.
Has anyone got this working at all?
I have customer with same issue.
Neil
