Cisco Jabber setup issue
May Chong
Try to setup Cisco Jabber and recommend to use advance setup.  With screen shot attached, I am not sure what option to select. Kindly advise.
May Chong
Ok, will do and thank you!
Jaime Valencia
That depends on your setup and how you're going to use it with the backend servers, if you're not familiar with this, you probably want to reach out to a reputable consultant or a Cisco partner WITH voice specializations for assistance.
Ideally, you should not be using any advanced options and simply use the SRVs to find the services you're going to use.
java
if this helps, please rate
May Chong
