Cisco Navigator not connecting to device
We have purchased a Webex Room Kit Spark with a Cisco Navigator.
The Navigator will not connect to the device. I have upgraded the firmware of the Room kit to ce9.15.3.17 so the Navigator should have followed the room kit device as soon as I connect to it.
I have factory reset the navigator many times, still. It will not connect. Checked all the cable connections, even used a switch.
I have connected a Touch 10 to the Webex room kit. That one connected just fine and it updated itself to match the room kit. So I know it is not the connection.
Did I missed something? Can someone please help me troubleshoot further?
If the Touch 10 works fine, but the navigator doesn't work at all on the same codec and cable, then it's likely a faulty navigator.   Contact the Cisco TAC to arrange a replacement.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
