Cisco Spark Single Sign-On with ADFS 2
meiercyrill
Hi everyone
Our company just bought a few Cisco Spark Boards and a license for every employee and I really like it so far.
But now my job is to configure Single Sing-On using MS ADFS 2.
I followed the following Tutorial: https://dede.help.webex.com/docs/DOC-8974
But the step to Import the  IdP Metadata is not working at all.
Did anyone had the same issue and how could you fix it?
Kind Regards
Cyrill Meier
keglass
Level 7
Level 7
Cyrill,
I found this page with a number of resources for Single Sign-On capabilities:
Tags | Cisco Cloud Collaboration Help Central
If you continue to have the same problem with your configuration, then I recommend you contact Spark support directly for help.
How to Contact Support | Cisco Cloud Collaboration Help Central
Kelli Glass
Moderator for Cisco Customer Communities
