cisco webex 55
siwar.ziadi1
i try to add nwe device Cisco webex 55 on CUCM  11.5.1.15900-18, but i canno't found a TYPE Cisxo webex 55, i juste found this type ( attached). so what shoud choose? Thank you
Then you didn't install the latest one, the latest one is: 11.5(1.16096-1) and the README does say it includes the re-naming of several endpoints, including the Webex Room 55
You're probably using the right option, but as you didn't install the DevPack that includes the change in the names, you don't see it.
java
if this helps, please rate
6 Replies 6
Jaime Valencia
Install the latest DevPack to see the product re-name to Cisco Webex Room 55
java
I installed the last device pack and I restart the server but some problem I canno't found the type Cisco webex room 55
What's the DevPack that you installed?
java
I installed cmetrm-devicepack11. 5.1. 16083-1,
By the way I added a Cisco webex room kit with the type Cisco spark room and it function
java
Thank you j'aime valencia, now i can found the device type cisco webex 55.
