CMS 1000 VM resource allocation question
danny.yf_li
Hi all
     Cisco document says that CMS1000 support up tp 96HD calls. My client purchased a CMS1000
and a SMP+ license for CMS. How should I edit the CMS vm  (vCPU, vRAm...) which was preloaded on CMS1000 in order to support 96HD calls? I can't find any document talking about this.
Thanks!
The VM specs for a CMS 1000 are what I explained:
2 sockets * 35 cores per socket = 70 vCPU (BTW, check your math)
58 GB of vRAM
Those are the specs the VM that came preloaded should have had.
2vCPU left for ESXi
6 GB left for ESXi and VM overhead.
java
if this helps, please rate
36 Replies 36
Jaime Valencia
The CMS 1000 should already ship with the required specs in the VM so you just turn it on, load the licenses and configure it.
java
Patrick Sparkman
CMS 1000 comes preconfigured from the factory and already supports 96 HD ports when it ships.
Thanks Java and patrick
      I checked the preloaded CMS VM . The VM was given 8vCPU and 16GB RAM.
According to Cisco CMS VM resource allocation
https://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/uc_system/virtualization/virtualization-cisco-meeting-server.html#notes
, 1vCPU = 1.25HD port. So 8vCPU=10.24 HD ports
How to calculate 96HD ports with 8vCPU and 16GB RAM. This is a bit confusing to me.
Thanks guys
Danny
Hi Danny,
if it's showing you 8vCPUs, something is not quite right.
Have you activated your VMWare license?
It seems that they're shipping with the defaults as if you use the OVA from cisco.com (8 vCPU / 16 GB vRAM), just had a call with a partner that got two CMS 1K with the same thing.
The ESXi license was the right one on their boxes
OP, do the following, shut down the VM, upgrade the VM HW version
Then adjust the specs as follows:
58 GB vRAM
Also reach out to your SE and let them know you also got a box with the wrong VM specs on the CMS 1K so the BU is aware, and they try to track this issue.
java
Hi Java,
      Thanks again for your comment. I have deployed 3 CMS1K so far. All of them came with 8vCPU, 100GB Harddisk  and 16GB RAM. The VM specification didn't change automatically even all licenses were applied (Including Vsphere combined key for 2CPUs CMS activation key and call license. eg pmp+ smp+ and CMSCU)
       The VM cannot be set as 2 sockets * 35 cores per socket but 2 sockets with at most 16 cores per socket
Thats makes the CMS1000 VM has Max 32 vCPUs. I did tune the virtual socket and cores per socket setting. The result were the same. The max CPU for CMS is limited to 32 vCPUs. This does make me confused. According to CMS Virtual machine deployment guideline provided by Cisco, such spec will not meet the requirement for 96HD concurrent calls.
VM version shows 8, did you upgrade the VM HW as I mentioned in my previous post??????
And the vRAM is also WRONG, it should be 58 GB, not 64. The server comes with 64 GB of RAM, if you choose 64, there's nothing left for the VM overhead and ESXi.
java
Hi Java
     I have just updated the VM from version 8.0 to 11.0.The vCPUs can now be set as 2 sockets and 3235 cores per socket. That makes it 7270 vCPUs (By the way,72 70x1.25=9087.5 HDports not 96HD ports). However I still have a question about the RAM. Cisco says that the RAM requirement is
Thank you very much for your help!
58 GB of vRAM
2vCPU left for ESXi
java
Thank you Java
    Sorry for my bad Math. ;-p .You did help me alot. I am still curious how to calculate 96HD ports if 1 vCPU=1.25 HD ports. Whatever, if 70vCPU and 58GB RAM can support 96HD ports, that is totally okay.
Danny
Since CMS1k is dedicated to CMS (and should not be running anything else, besides ESXi), the calculations on the Virtualization Wiki do not apply to it.
With the correct setup, it can handle the number of calls described in documentation.
If you look closer to the Virtualization Wiki, it does say that the tables do not apply to some hardware (like CMS1k). This is because the Virtualization Wiki assumes co-residence with other VMs.
Hi Jaime
Cisco states in the VM requirements for CMS to allocate 1GB RAM per 1 vCPU. So why are you saying to allocate only 54GB RAM when 72 vCPUs are configured?
Hey Danny,
This is because you're currently running VM version 8 which only supports 32vCPUs. You'll want to upgrade the VM hardware by right clicking on the VM and hitting Upgrade Virtual Hardware. Once you've done this you'll be able to configure the VM with 2 sockets with 35 cores each.
Please let me know if you have any further comments, questions, issues, or concerns.
Kind regards,
Ben Andrews
Hi guy,
your procedure is valid also for CMS 1000?
My customer want add more vCPU but initial OVA that i provide was for CMS 1000.
