CMS 2.x configure for write and export CDR on CDR Receiver
Dear all,
I have configured the CMS 2.0.7 (ex Acano) and everything works, I now have to configure the CDR to control calls statistics. I followed the CDR and API guides to create the CDR Receiver ... like this http://10.10.10.10/CMSCDR. We have tried via GUI and via API....
API 2.0 - CDR 2.0
I don't have Acano Manager,it is not necessary according to the guide.
The CMS does not report connection errors.
I have not found what are the characteristics of "CDR Receiver", IIS, WEBDAV, Apache, SFTP, FTP, Share...etc.
If the CMS has to write the files, how it does?
Any help is appreciated.
Thanks a lot
Massimo
16 Replies 16
sudo apt-get install python3-pip
sudo pip3 install wechatpy
python3 acano_cdr_receiver.py -f cms.txt
and it's work for me!
Did you ever resolve this issue? I'm having exact same problem
