Configure WebURL on Webex Hardphone
mthijssen
On an CUCM you can configure an custom WebURL on an Hardphone button. When you press this button, the weburl is triggered.
Is this also possible on an Hardphone on the Webex Calling platform? I cannot find an option for this.
Jonathan Schulenberg
I’m not aware of an option to define this in Control Hub, although the MPP Admin Guide suggests that the phone firmware does support XML web applications. Unless someone else chimes in with a better answer I suggest looking for an existing feature enhancement request to upvote - or creating one with the use case and business justification for prioritizing it.
