CUAC Advanced Reporting
noc mcc
Level 2
Level 2
Dear all,
I wish to know the database queries required to extract all the data which comes under CUAC Reporting Tab.
We have an external monitoring server through which we want to query CUAC DB and showcase the reporting features. This is done coz users do not have access to CUAC server.
Kindly help in this matter
Avi
Jonathan Schulenberg
To my knowledge Cisco (or Arc Solutions, the underlying ISV that Cisco is reselling) does not publish the database schema or the built-in report queries. That said, you could presumably turn up logging on the MS SQL instance, run a built-in report, and see what stored procedure or query is executed.
Thanks Jonathan,
Has any one attempted to extract the above mentioned stored procedure ?
NOC MCC
