CUC Voicemail Storage Capacity
Flo.Matalis
Hi Experts, I am a bit confused about the capacity.
CUC 14 / 5000 users OVA
Found these documents:
1. If this is the correct source, where I can change or set this? I tried to check from the server, and I do not see this option.
Source: https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/12x/administration/guide/b_12xcucsag/b_12xcucsag_chapter_01000.html
2. Found this as well. Not sure if which is correct. Basically, our client just want to know what is the Voicemail Storage Capacity of the entire server? Note: We only have 1 node of CUC server.
Does above mean 137, 298 minutes?
Source: https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/14/supported_platforms/b_14cucspl.html
b.winter
About 1: Edit: In Unity Admin --> Message Storage --> Message stores
About 2: Your screenshot answers the question ';)'
@Flo.Matalis any update here?
