CUCM Inbound\outbound call recording based on DTMF digit
Genadi
Is it possible to automatically enable call recording for inbound call from PSTN to CUCM internal phone based on DTMF digit ? I mean IVR is asking calling party if he is okey with that the call will be recorded and if yes then calling party press 1 if no he press 2?
I know that i can enable recording options as selective so CUCM phone can enable\disable recording on demand but i need to do it based on pressed digit.
The same question is regarding to UCCX.
Jaime Valencia
CUCM has no IVR to do what you're asking, the built in IVR in CUCM only works with some features and you cannot create new ones.
java
if this helps, please rate
I mean call is coming to CUCm but IVR can be on CUC or UCCX. Now i am recording all calls using 3-party solution but i need an answer if it is possible to record calls in which promt from CUC or UCCX will be also recorded as one file?
Steven L
not contradicting java at all, but you might be able to script something. it wont be easy or quick. i would advise talking to your recording solution provider.
i have done something like this in the past but it was complex and difficult to support, meaning i was the only one who could support it.
