Eurl Bot Not Working
ksigmon
I am trying to use a link to a Webex Teams Space generated by Eurl so others can join using the link. However, when you click on the link (https://eurl.io/#Bku7FKzgU) an error message appears. I've tried with multiple URLs and the same thing is happening
Gasper A
Sounds like an issue with the Bot's workflow itself. You should reach out to developer support. If you are trying to join with an external account (non-Cisco account), make sure you have enabled this for the space you are trying to join.
