Record local audio WebEx Codec Pro
TorgeRuge
Hi there,
we are currently working on a situation, where we have to be able to record local (and if possible also remote) audio for important meetings.
Best solution would be to hit a record button on Touch10 which is connected to a WebEx Codec Pro and it records to a recording device e.g. connected to the audio out of the codec or to a local usb stick which is connected to the codec. It should also work if there is no active call. It does not matter what kind of recording device we need to buy but we do not want to store the files outside the room ;-)
Is there any chance to handle this with Codec Pro?
Thanks a lot
Torge
Mike_Brezicky
I am not sure about an inactive call, but the Pro / Audio Console allows you to manipulate Audio outputs. With that and some macro work, you should be able to manipulate a call recorder.
