Expressway Edge - Crashes with SYN Flooding on port 7001
Dears,
I recently build a collaboration edge for MRA usages. All are working as expected. I was having good days. But suddenly my expressway edge is getting crashed and not responding. I can't even ping the expressway edge IP address. when I logged into vsphere and check the console, I found the message - TCP: request_sock_TCP: Possible SYN flooding on port 7001. sending cookies
I have to reset the expressway VM instance to bring up the edge server every time the issue occurs. also noticed below event entry in the expressway edge server
2019-09-26T09:46:30.550+01:00kernel: #PF error: [normal kernel read fault]
2019-09-26T09:46:30.550+01:00kernel: BUG: unable to handle kernel NULL pointer dereference at 0000000000000008
any help will be appreciated.
Shalid
Apologies guys,
I believe i got solution for my issue. it seems to be a bug
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvq39993/?rfs=iqvred
Let me upgrade and see if it resolve.
I am experiencing the same problem - did the upgrade solve the problem?
@Shalid Kurunnan Chalil wrote:
Apologies guys,
