Expressway MRA maximum registering devices exceeds 2500
drkwbr
Hi guys,
one question for my better understanding.
What happens, if the quantity of registering devices exceeds the maximum of 2500 per Expressway node?
Is the registration of these devices rejected on this node and Jabber will try to connect to another node in cluster, if configured.....
Or will these devices registering with the node?
And in this case the node will go to, I call it now, "overload" with 2501+ devices?
KR
Dirk
Vinod.s
Level 3
Level 3
No licence is required for MRA.
Expressway MRA setup is based on user based only and capacity exceed then it will go for another MRA Setuo, if HA Exist..
If no HA then might be user will not able to login beyond 2500
