How To Collect VXC Client Logs Outside Jabber Problem Report
JustJeff
I have Jabber running on a Citrix virtual workstation and JVDI running on the physical workstation. I am trying to make a utility / script that would effect pulling a Jabber Problem Report without user input from the virtual workstation. I am able to gather all of the information I need, except for the VXC client logs, as those reside on the physical workstation, along with JVDI.
Is there a way to pull these logs, programmatically, similar to how the Jabber does with the 'Report a Problem' function?
Otherwise, is there a way to initiate a silently create a Jabber Problem Report, so the user doesn't need to enter any information and doesn't see any dialog windows?
Miguel E Castillo Torres
Hello!
The log location for the JVDI Client and Agent are the following:
JVDI Client:
%localappdata%\Cisco\VXME\
JVDI Agent:
%appdata%\Cisco\Unified Communications\Jabber\
%localappdata%\Cisco\Unified Communications\Jabber\
%localappdata\Cisco\Unified Communications\Jabber\CSF\Logs\Virtualisation\
You can write a script that access to those locations and retrieve the files and folders inside them.
Regards, Miguel Castillo
Does the Jabber Problem Report only gather JVDI Agent logs and not the JVDI Client logs? I am looking for a way to gather all of the logs from the context of the machine where JVDI Agent is installed, not JVDI Client.
