how to get the maximum of active call in a voice gateway of H323.
yuexp0929
Hello All
    My CUCM is version 10.5.   All Voice gateways are using H323 and connecting pstn with E1.   I want to know the maximum of active call in a H323 voice gateway.   I will decide if add or reduce the E1 line base on the data.
Anurag Srivastava1
Please see the below link-
https://community.cisco.com/t5/ip-telephony-and-phones/max-pri-concurrent-channel-usage-reports/td-p/1625422
Hope this helps
Thanks.
Please rate if it is helpful...
Please rate if it is helpful and mark as accepted solution if applicable....
Anurag Srivastava1
Hope this helps
Thanks.
