How to redirect WebEx from http to https
FcNongTanong
Community Member
We have any question about WebEx on premise server. We just want to know how to redirect http://testwebex.com to https://testwebex.com. So please inform us how to configure that on WebEx server side.
Dejan,
Thanks for confirming.
Guys as per my original post I have double checked as well, for my deployments automatic redirect is happening for both the sites Admin and User. As Dejan has mentioned worth checking your firewall.
Here is whats mentioned in the planning guide:
http://www.cisco.com/c/en/us/td/docs/collaboration/CWMS/2_0/Planning_Guide/Planning_Guide_chapter_011.html#reference_125F962B1D20407186B1654C7A3F5873
Cisco strongly recommends that you open port 80 (http) in addition to port 443 (https), to simplify the end user experience (in a browser, users enter the WebEx site URL without having to remember whether it is http or https. However, for this product, the actual network traffic always flows over port 443 (SSL encrypted https).
-Terry
Please rate all helpful posts and mark the thread as answered if you have no other queries
8 Replies 8
boom98chalit
Community Member
I have this problem too
Please help us
thank.
Hi Guys - I am not in front of the console so cant check exactly but as far as I remember, if you enter the http it automatically redirects to secure http. What are you trying to access, admin/user site? From where internal or external and whats the issue you are seeing exactly?
I dont remember there is a special configurable setting on CWSM. I will try to logon and check as well but if you move this thread to Conferencing you will get a swift response from Dejan (from Cisco).
-Terry
Hi Bro,
This is user site we found that not automatic redirect.(for admin page we not try) And thank you very much for inform. We already change this trade to Conferencing.
Good one. I cant remember off the top of my head now, I will try to update the thread tomorrow. Dejan is normally quite active and hopefully will pick this up by then.
-Terry
Hi guys,
There is no configuration on CWMS side for re-direction. If you allow both port 80 and 443 for accessing WebEx Site URL, you should be automatically redirected. Most of the time I've seen redirection not working is when the firewall is blocking these ports.
It is the same for both Admin and WebEx Site URL.
I hope this will help.
-Dejan
Dejan,
-Terry
Hi Dejan,
Thank you for answer. We should be check firewall already allow port 80 for this CWMS right ?
So if allow port 80 for this CWMS on firewall these should be auto re-direct from port 80 to 443 ?
-Tanong
Hi Tanong,
That is correct. As Terry quoted from the documentation, if you open both ports 80 and 443 to WebEx site, CWMS will automatically redirect you to HTTPS.
Dejan
