03-18-2019 12:39 AM
Do you know if it is possible to test the O365 hybrid calendar integration with Webex Teams Trial account?
I have the following error upon the last step of the Hybrid Calendar Setup (Test Account).
Thanks for your help !
03-18-2019 10:18 AM
Hi there
Unfortunately for Exchange/Outlook integration you need a paid org account. Not a free consumer account
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
03-18-2019 11:06 PM
Thanks for the quick reply Ratheesh.
I have tried as well with a Paid org and I still have the same issue.
Anyone faced a similar issue in the past?
03-20-2019 01:13 PM
Hi there
Where exactly are you facing issues. I have this setup and working all good.
Have you successfully authorized calendar service using a Office 365 Global administrator account. Is the calendar service showing as "Operational".
Or is this under the user level, can you de-reactivate and reactivate or even delete the user and try again.
Hope this Helps
Cheers
Rath!
