iPad jabber for VCS running 384 only
It seems the iPad client only runs at 384kbps, no matter how I set provisioning. Movi over the exact same path works just fine. there are no limitations set to 384 anywhere. Is this a bug?
best regards
Rob.
10 Replies 10
Will Colston
I am having the same problem. When I use the Polycom App, it connects at 512 but Jabber will only connect at 384.
Patrick Sparkman
I can agree that I'm seeing this as well, I've tried it so many different ways to provision the call rate with unsuccessful results to go higher than 384, even setting our VCS to use unlimited bandwidth for all endpoints.
I've experienced this too. Calls to and from the iPad client are only at 384k.
This only occurs in sip calls though, calls FROM a H.323 endpoint or MCU connect
at any speed OK... but calls from the iPad to the 323 endpoint or MCU are still at 384k.
The Template can restrict the bandwidth.. when set to 128k the calls are limited but
it won't allow anything above 384k when the template is set to 768k for example.
I've tried this in 2 environments with the same results. VCS x7.1 TMS 13.2.1
I've raised this to Cisco TAC on Friday and they have confirmed that they can replicate
the issue in their environment so they are looking into it.
That's good to know, I'd like to know what they come up with or can provide since they were able to replicate the issue.
rpomerleau
Same issue here. Hopefully a resolve is quick to come out
Sent from Cisco Technical Support Android App
craigsimons - Any update on what TAC has found out on the call rate issue?
Hi.  I'm assuming everyone has the max in and max out bw set on the iPad for something other than 384?  If you run debug on VCS, the NOTIFY with provisioning data shows this?  Can someone confirm for me?
Thanks.
VR
P2
Patrick - According to my VCS logs the provisioned call rates are set to 768.  Let me know if need anything else, or would like the logs.
Thanks Patrick.  I think I see it now, but wanted to confirm I reckon.
What I'm seeing is that the provisioning data in the NOTIFY from the VCS is sending:
NOTIFY sip:papettit@x:63018;transport=tls SIP/2.0
Via: SIP/2.0/TLS x.x.x.x:5061;egress-zone=DefaultZone;branch=z9hG4bKd90c8d119509fdf13f03a8127c84faad765414.b595285722cebe6b10db29b9dac49bbf;proxy-call-id=b0679834-dcab-11e1-8164-0010f30f5600;rport
Via: SIP/2.0/UDP 127.0.0.1:22410;received=127.0.0.1;ingress-zone=DefaultZone
Call-ID: 2f9159ac20250335@127.0.0.1
CSeq: 1687 NOTIFY
Contact: "VCS Provisioning Service" <127.0.0.1:22410>
To: ;tag=097ba8bc881e1a19
Max-Forwards: 69
Record-Route:
Record-Route:
Event: ua-profile;model=jabbertablet;vendor=tandberg.com;profile-type=user;version=1.0.0.0;clientid="235efa17-65b9-c04b-a99e-25c1d7ad315b";connectivity=0
P-Asserted-Identity:
Subscription-State: terminated
X-TAATag: b0679992-dcab-11e1-bfce-0010f30f5600
Content-Type: text/xml
Content-Length: 603
http://www.tandberg.net/Provisioning/2/">1920multiway@tac.labPatrick Pettit1920taccluster.tac.labpapettit.jabbertablet@tac.labphonebook@tac.labpresence@tac.lab
The log from the tabblet shows:
Thu Aug  2 10:03:52 2012
: TAF: Provisioning : Provisioning succeeded - configuration: 1920
1920
High
Off
Off
Patrick Pettit
21000
21900
multiway@tac.lab
30
Off
Off
Off
TRUE
TRUE
TRUE
TRUE
TRUE
The app still sends out the call in the outgoing INVITE setting the bandwidth at 384k.
I'm trying to provision max in and max out with 1920, but still launching at 384k.
I've raised an issue for this, so will post it if we make some traction on it. For now, I can't think of any work around at the moment.  My apologies, but an issue has been submitted, so will work to get it looked at.
VR
P2
Valentin Ichim
Acc to the Release Notes for Cisco Jabber for iPad : " Cisco Jabber for iPad bandwidth has been limited to 384 kbps due to CPU constraints on the supported iPad hardware ". Quite strange, taking into consideration the CPU of IPad 3...
