01-22-2018 10:57 AM - edited 03-17-2019 07:17 PM
We have Jabber users (11.9) that are creating custom locations to indicate an office/extension they will be using for the day. This changes on a regular basis and these users are not assigned their own, unique extensions so this is a great way for someone to find one of these users as we allow the locations to be shared across everyone. However, the only problem we are running into is when one of these users either locks their PC or their PC goes to sleep. The default Away status in Jabber does not show the location. I know they can use the custom Away messages but that means they have to remember to change it before they lock their PCs. And, most of the time, these users are allowing their PCs to go to sleep, doing other work, so manually changing the Away status doesn't fix the issue. Does anyone know if there is a way for the location to show for the default Away status?
01-22-2018 11:44 AM
No, because that is WAD according to how the product was designed, you would need to reach out to your SE/AM to submit a PER with the business case to ask that to be changed.
Right now, if you go into the automatic away mode, the location will be removed.
01-22-2018 11:55 AM
01-23-2018 03:49 PM
