Jabber can not resolve contact for incoming calls
umutyasar
Hi All,
We're using access-code "0" to call external numbers and using a translation pattern to add pre-leading 0 to incoming calls to use callback function on the desk phones to call missed calls back. As a result of this incoming caller-id displays as 00xxxxxxx on our phones. It is working fine.
The problem starts when we start to use cisco jabber. There is 00 now for the incoming caller id, jabber can not resolve the names to numbers even if they're in Outlook Contacts and LDAP, since the numbers are saved as 0xxxxxxx on them.
Is there any solution to this problem? Can jabber discard pre leading first 0 from incoming calls? Or can I do something in the call manager to fix this problem?
create a calling party transformation pattern for jabber users:
pattern: 0.0xxxxxxx
Assign it to a partition
Calling Party Transformations
discard digit: predot
under the CSF device configuration, configure calling party transformation CSS having above created partition.
umutyasar
Hi All,
I researched that I can use "Calling Party Transformation" as a solution.
Can anyone explain to me the example configuration steps for this solution for my problem?
I want to remove pre leading 0 for the incoming calls.
pattern: 0.0xxxxxxx
Hi Sudaggar,
Thank you for your reply.
The solution worked perfectly.
To be more clear where to apply Calling Party Transformation CSS under the CSF device configuration, "Number Presentation Transformation->Remote Number"
Even if I have a translation pattern configured to add pre leading "0" for callback for missed calls, the Transformation pattern is doing its job and deletes the same "0".
I read there is other option to do the same job;
If I want to do this for a large number of phones, I could also do it at the device pool level.
Under Device Mobility Related Information > Calling Party Transformation CSS
Select the Calling Party Transformation CSS.
I can use the same CSS that I created for the CSF device, Is it correct?
thats correct.... you can apply in device pool configuration as well for multiple devices.
Sudhir Aggarwal
