Jabber Client and voice recording
Thomas.Mohrmann
I have to voice record all calls made via a jabber client.
Does the jabber client support voice recording?
Does the jabber client support DMS (Dual Media Streaming)?
Thomas
Jonathan Schulenberg
The CSF client is not currently supported by the BiB Recording feature of CUCM. You could use a PC-side application to capture audio from the speaker output and mic input though.
Please remember to rate helpful responses and identify helpful or correct answers.
Hi , II thought it is possible with , VPN Jabber users , and have the voice recording within the UC-APPS LAN - with BIB and voice gateway-only issue would be use NO VAD enable to GWAY , then , it is possible to do the Voice recording .
only issue may be ,voice quality may not be guaranteed , if the user is remote - but within the on-perm and use of Codec g711 helps .
Sam
