jabber for IPhone issue
islamahmed
Cisco jabber was working well from my Iphone but after an update i can't login to cisco jabber, I tried to open it from another iphone and working.
Is there is any thing to do from my IPhone
"cannot login outside corporate network" error appears.
6 Replies 6
vijit kumawat
Try deleting the iphone app reboot phone . Reinstall app then try again.
I did that , but not working
Try to confirm the sip profile is using the mobile default profile on ccm
When I changed the time for IPhone to Automatic, Jabber working
DO you know what is the reason ?
You mentioned same login is working on other iPhone ?
Can you specify the version of Jabber and the IOS on non-working iPhone and working iPhone ?
