06-19-2013 05:58 AM - edited 03-17-2019 03:19 PM
installed jabber on two laptops.
when connected to LAN works OK
when connected with VPN from home with "use my computer for calls" :
i can make calls by typing the number in the search bar and receive call OK.
but not call from contact list or searched list - the dial button is missing. and "show profile" does not show the number.
also the name of the caller is displayed from the "
thanks for any help
06-20-2013 05:18 PM
I think you have more or less already given the answer; you cant connect to you AD server through the VPN. check your access lists and routing between VPN client and AD.
(check wireshark when on VPN)
Please remember to rate useful posts, by clicking on the stars below.
06-22-2013 03:09 PM
tried wireshark
i dont see the client trying to connect to AD server
i see it using:
CUCM server
Unity Connection Server
Presense Server
06-23-2013 08:34 PM
Is this on a windows machine, part of the domain when on VPN?
also you might want to include/attach the Jabber problem report
