08-28-2014 05:54 AM - edited 03-17-2019 04:26 PM
Hi there,
We just installed expressway E and C Ver X.8.2 for mobile and remote access Jabber Vpnless and we are planning to deploy jabber guest.
My question is as follow:
Thank you in advance
Solved! Go to Solution.
08-28-2014 09:24 AM
The Expressway does not support MRA and Jabberguest on the same server/cluster. Therefore, you'll need to deploy another expressway cluster..
08-28-2014 09:24 AM
08-29-2014 01:05 AM
Thank you Jalumbau; I really appreciate your help.
