jabber guest web without iframe
g.vlekke
The document  "Jabber Guest web SDK"  describe how to use Jabber guest with a iframe.
Is there a supported (and maybe documented) possibility to use jabber guest without the iframe? and include the code directly in a app so we can customize it?
mrmccann
Hi - in current releases we don't support customization of the Jabber Guest web interface.  Using the iFrame is the only supported way to embed Jabber Guest into a web application.
Mike
