Jabber outside login issue
eng_ali_83
Recently we have finished deploying Expressway-C and E (MRA) version 8.10 as well as CUCM 11.5 , everything working well from inside our organization , we can successfully login from Jabber for windows (version 12) and successfully calling each other , we are using it just as Softphone for audio calls only.
When we try to login using Jabber from outside the organization we can not login , each time we got error message saying Username or Password is not correct.
The same user that can login from inside the organization can not login from outside for the same reason(username and password).
Any suggestion please
Thanks a lot
5 Replies 5
Dennis Mink
are your srv records correctly pointing to the public IP of the VCSe- public IP address? can you share
_cisco-phone-http              (SRV),[10][10][8443]        uk-cucm-01.company-internal.net
_cisco-uds                           (SRV),[10][10][8443]        uk-cucm-01.company-internal.net
_cuplogin                            (SRV),[10][10][8443]        uk-cups-01.company-internal.net
_sip                                      (SRV),[10][10][5060]        uk-cucm-01.company-internal.net
_sips                                    (SRV),[10][10][5061]        uk-cucm-01.company-internal.net
and also can you check the logs to see if the authentication requests hit vcs e and c
Please remember to rate useful posts, by clicking on the stars below.
Thank you for your reply , all of these SRV records that you post is for internal DNS , we only use Jabber and MRA for voice call , we dont use CUCM IM & Presence , so I only used _cisco-uds_tcp.example.com and it resolved correctly to our CUCM pub server :
DNS request timed out.
timeout was 2 seconds.
_cisco-uds._tcp.example.com SRV service location:
priority = 0
weight = 0
port = 8443
svr hostname = cm-pub.example.com
cm-pub.example.com internet address = 10.100.100.180
R0g22
Public DNS should only have collab-edge TLS SRV record which would resolve to the Ewy-E public address. Your UDS or cup-login SRV should not be present on the public DNS.
Have you ensured this ?
What is the authentication that you are using for MRA ? User creds, OAuth etc ? I am talking about MRA access control.
Thanks Nipun for your reply , yes I am 100% sure that only collab-edge is resolvable from External DNS , no other SRV can be resolved from there.
I am using OAuth , we have LDAP connection between CUCM and Microsoft Active directory , is that what you meant?
There is one update just got it today that I can login externally (from the internet connection) after 4 attempts of entering my username and password , I know it seem weird but I have tried it from more than three devices , Jabber keep saying your username or password is not correct until I enter my username and password for the fourth time after that I can login , still Jabber phone service is not working so I can not make any call also nothing registered to CUCM.
We have 4 CUCM 11.5 , one Pub and three sub no CUC nor IM&presence
