Jabber without AD, possible ?
experts,
is it possible to use Jabber window and iPhone without AD ?
we sometime has AD down
tks,
K
Jaime Valencia
That depends on what you want.
You can use CDI or UDS for directory integration. Just as you can use local or LDAP users for user provisioning and authentication.
java
if this helps, please rate
do you have cisco doc for that?
what is the limitation of each approach & how to?  CDI and UDS
K
Refer to the directory integration chapter of the Jabber docs.
java
