MCU License with/for Cisco TelePresence System
Manthan Shah
One of our client needs "Cisco Telepresense Profile 42 with Codec 40".
So i have suggested "CTS-P42C40-K9" option.
But they asked us "Built in MCU (should purchase the MCU license)" with the Cisco Telepresense system.
So anyone can suggest thtat is this part number is correct as per requirement? or i need to take any other devices?
Does Cisco Telepresense System has built in MCU? I can't find any MCU License option with selected CTS Device.
We need it on very urgent basis, i appreciate if you can provide information asap.
Manthan
admin11111
Level 4
Level 4
This system includes the C40 codec so it does have an built-in MCU, or Multisite feature that it is called.
You can see more regarding the Multisite capability of the C40 codec at:
http://www.cisco.com/en/US/prod/collateral/ps7060/ps11304/ps11312/ps11332/data_sheet_c78-628593_ps11422_Products_Data_Sheet.html
BR
Eivind Christensen
Product Manager TelePresence
Thanks you for your quick turn around.
I know its wiered question but just want to confirm.
Our product "CTS-P42C40-K9" has built-in MCU?
Data Sheet - http://www.cisco.com/en/US/prod/collateral/ps7060/ps11302/ps11326/data_sheet_c78-628587.pdf
Or we need to buy "CTS-C40-K9" device for MCU?
For the detailed information, please check below hardware configuration.
CTS-P42C40-K9Profile 42 in w C40 - PHD 1080p 12x Cam, NPP, Touch, 2 Mics
CTS-C40CODEC-K9-Codec C40 buried option
CTS-CTRL-DVC8+InTouch 8 - Control Device- + PID for Service
CTS-DNAM-III-DNAM III buried option
CTS-MIC-TABL20XLR+XLR Table mic - for auto expand only
CTS-P42MONITORMonitor Assembly 42
CTS-PHD-1080P12XS+PrecisionHD 1080p 12X Unit - Silver, + indicates auto expand
CTS-RMT-TRC5Remote Control TRC 5
LIC-P42SC40Profile 42 C40 Product ID
LIC-PCXX-NPPProfile Series NPP option
CTS-P4252S-WBKProfile 42, 52 and 55 in single screen Wheel Base Mount Kit
PWR-CORD-UK-APwr Cord UK 1.8m Black YP-61 To YC-12
LIC-S52000-TCX.XK9License Key Software Encrypted
SW-S52000-TC5.XK9Software 5.x Encryption
LIC-P42C40-MSProfile 42 with C40 MS option
LIC-P42C40-MS - This license actually for MCU? I checekd on one of the 3rd party website.
-> LIC-P42C40-MS (MS): built-in 4-square w576p capacity MCU
http://openav129506.en.b2b168.com/shop/supply/23977300.html
Manthan
The CTS-P42C40-K9 has built in MCU – or Multisite feature that is the name we have given it.
You can see that the SKU includes "C40" and that means that the codec used in that system is an C40 – so that system will have all the capabilities of an C40.
You can also see from the list that you sent me that it includes:
LIC-P42C40-MS --> this is the MultiSite that is the same as built-in MCU.
BR
Eivind
Eivind, You are amazing!!
Thats perfectly what i want to know.
Thanks a lot
Manthan
