MRA - How does Expressway-C choose a Call Manager
Bill
I am wondering how Epxressway-C decides which Call Manager to authenticate user's against.
I thought it might use weights from the internal DNS for _Cisco-UDS, but it does not seem to.
I am looking for a workaroundto an issue.
One CUCM server has DNS/Domain issues, and when Exp-C tries to authenticate a user against this CUCM, it fails.
It it chooses a different CUCM server it works.
I know the correct fix is to fix the root of the problem.
But raises the question - How does Exp-C decide which CUCM it uses?
Jaime Valencia
It uses _cisco-uds for internal resolution, if it's a multi-cluster environment and several clusters share the same domain, it will also rely on ILS in case the user is not found in the cluster where _cisco-uds is pointing to.
java
if this helps, please rate
Thank you Jaime
I have set DNS SRV priority for the Sub to be less preferred (higher value) than the Pub, but it still often times wants to use the Sub.
I am seeing this in the Exp-C log:
Unable to determine home CUCM
Reason="Unknown CUCM cluster for node"
Node=sub1.localdomain
localdomain is not the correct domain.
But I cannot change it now.
So I was hoping i could just change the DNS priority and force Exp-C to use the Pub, which has correct Domain name.
Working around the issue is probably more effort than just fixing it.
One suggestion would be to temporary remove the SRV record for the faulty CM node until you get around to fix the underlying problem with it.
Response Signature
Good suggestion Roger.
We ended up fixing the underlying issue and renamed the Call Manager's domain.
