SCCP ACTIVE_IN_PROGRESS - Cause Code: TCP_CONN_ERROR
I need to configure Media Resources on a 2811 router to register with Call Manager.
I have the configuration of "voice-card", "sccp", "sccp ccm group" and "dspfarm profile" for conference, transcode and mtp.
However, when executing the "show sccp" command, it returns with the following error:
Priority: N/A, Version: 6.0, Identifier: 1
Trustpoint: N/A
Conferencing Oper State: ACTIVE_IN_PROGRESS - Cause Code: TCP_CONN_ERROR
Active Call Manager: NONE
TCP Link Status: CONNECT_PENDING, Profile Identifier: 1
This is the result of the "debug sccp all":
002538: Feb 26 2020 09:28:20.560 BR: sccp_connect_to_ccm_on_priority_basis: Trying connecting to CCM on priority basis prof_id 2, appl_type 1
002539: Feb 26 2020 09:28:20.560 BR: sccp_connect_to_ccm_on_priority_basis: Trying CCM with ipaddr 10.20.0.3, priority 1, port 2000
002540: Feb 26 2020 09:28:20.560 BR: sccp_tcp_socket_connect: Trying tcp soc connect for appl_type 1, prof_id 2, to ipaddr 10.20.0.3
002541: Feb 26 2020 09:28:20.564 BR: sccp_get_ccm_intf_vrf_id: ccm sccp local interface vrfid=0appl type is 1, appl profile 2
002542: Feb 26 2020 09:28:20.564 BR: sccp_tcp_open_and_set_option: Socket 2 opened and binded to addr 10.20.0.3 - for appl_type 1, prof_id 2
002543: Feb 26 2020 09:28:20.564 BR: sccp_socket_connect_to_ccm :: connecting to port 2000
021-SINOP(config)#sccp_socket_connect_to_ccm: soc conn to 10.20.0.3 port 2000 in progressfor appl_type 1, state 1, soc_fd 2 appl 49E95028
002544: Feb 26 2020 09:28:20.564 BR: sym_xapp_xlate_ccapi_eve: Unsupported ccapi eve 2
002545: Feb 26 2020 09:28:20.564 BR: sym_xapp_process_ccapi_events: Unsupported ccapi eve_id 2
Could someone explain to me what the last two lines mean? I looked for similar cases in the community but what I found did not solve the problem.
I found suggestions to change the IP Precedence of SCCP and to change the version of SCCP to a newer one and none of them resolved.
There is another line which I haven't found an explanation:
002462: Feb 26 2020 09:28:20.536 BR: sccp_oper_state_bring_up: Not able to create MP Auto-Config process
Thanks in advance.
Thank you so much for your help but it turns out that it was a problem in my client's voice network and as soon as he fixed the problem it was solved. Still, your comments were very helpful. Thanks.
Is the IP Voice Media Streaming App Service running on the CUCMs that the resource is trying to register to?
If that isn't the issue, please provide resource-related parts of your config. (voice-card, dspfarm profile, the sccp commands pointing to the CUCM servers, and the sccp ccm group) And also a screen-shot of the resource as configured in CUCM.
The issue indicates a mismatch of parameters.
Maren
