some jabber problems
born.jason
Hi All,
I use cucm 8.6.2.20000-2 with LDAP Sync/Auth And Presence 8.6.2.10000-44
I`m playing with Jabber and have some issues:
1. The displayname (in the Top of Jabber) is not showing the name correctly, it shows userid@ldap.domain instead "First, Lastname"
2. I can search for User in Jabber but if I add them they appear for a millisecond in the user list but then disappear again
3. I cannot chat with a online member because they show each other as offline but i know both are online
I`m right that i do not need an jabber-config.xml if i use EDI (for EDI i have nothing to configure, right?)
In the Presence Troubleshooter are no issues.
Cheers
Jason
Jaime Valencia
In theory you shouldn't, but in my lab where my machines are already part of a domain I faced similar issues, I checked that they were registered in my domain, I could only log with domain users, DNS, etc but I also couldn't get name resolution nor add users if not using their full name@domain.com format. For some reason some of the searches would return the CUCM / Users and devices and not LDAP users.
I could chat with my other test user and get his status correctly.
I had to configure the ldap server, and user search base in the .xml file for this to work.
Not sure if this problem was related to either an LDAP/DC/GC config missing or maybe a DNS SRV entry missing.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Do you use UDS or EDI ? Could you share your config?
Jason
After adding the to the XML all is working. I use EDI.
