Spark Hybrid Call Integration
Adrea.B
Hello All,
I'm newer in Spark, and i'm trying to create the integration between Spark Calls and my on premise system.
Are only Cisco solutions supported or I can link SparkCall with my system? I have in lab one installation of 3CX, and Siemens.
Second Question, Autoattendant, is only avalaible in Cloud Call configurations?
Thanks a lot
Andrea
skilambi
1. Spark call hybrid is tested and supported with Cisco UC system
2. Yes AA is a supported feature with spark call
Getting Started with Cisco Spark Hybrid Services | Cisco Cloud Collaboration Help Central
Cisco Spark Hybrid Services Design Guide - Cisco
Thanks a lot .
Do you think in future other system will be support?
Andrea
Nope no plans it's a feature for Cisco on premise to tightly integrate with Cisco cloud solutions
